magneto Posted May 20, 2015 Share Posted May 20, 2015 Hi, I am getting this kind of patterns in my pyro. I increased substeps slightly but didn't fix it. Anyone know why I am getting these and how to fix these? Thanks Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted May 20, 2015 Share Posted May 20, 2015 Maybe try lowering CFL condition? 1 Quote Link to comment Share on other sites More sharing options...
anim Posted May 20, 2015 Share Posted May 20, 2015 seems like your source is not moving between frames, if there is no movement, substeps will not solve it - so if your source has constant topology, then Timeblend can help - if not then you can smear it using velocity along the full frame or timestep to avoid obvious stepping - if you are caching source before, make sure you cache subframes or maybe the the problem lies somewhere else, difficult to judge from the picture 1 Quote Link to comment Share on other sites More sharing options...
TheDude Posted May 20, 2015 Share Posted May 20, 2015 If you're super screwed and can't get good topo on your source for substepping I've found forcing a lil bit of vel into the presolve smudges the emission enough to get away with it, but its a bit of a gamble 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted May 20, 2015 Author Share Posted May 20, 2015 (edited) Thanks a lot guys. All I did is used billowy smoke, added fuel in SOPs and enabled combustion and then set the sim to be 2D, and lowered the divisions. Then I got this pattern I attached the file. pyrosim.hip Edited May 20, 2015 by magneto Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted May 20, 2015 Share Posted May 20, 2015 Thanks a lot guys. All I did is used billowy smoke, added fuel in SOPs and enabled combustion and then set the sim to be 2D, and lowered the divisions. Then I got this pattern I attached the file. There's no attachment. It looks like insufficient substeps to me. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted May 20, 2015 Author Share Posted May 20, 2015 Sorry I always forget to press the attach button after selecting the button. Now attached. Quote Link to comment Share on other sites More sharing options...
anim Posted May 20, 2015 Share Posted May 20, 2015 seems like increasing Pyro Solver/Advanced/Max Substeps does the trick 1 Quote Link to comment Share on other sites More sharing options...
