wateryfield Posted May 25, 2015 Share Posted May 25, 2015 (edited) Hi, everyone. There are two object, one of them with translate and rotate, and another was keep static. Now i want get the trans and rot matrix of first object, then apply it to second one. I have to search transform matrix for long time, and learn copying and instancing point attributes, but still confused with the matrix. So i post a simply file for help, if anyone give me some tips will be great! Is transform matrix can export as a point , such as packed represent point . And transform object by wrangle will be great too. Thanks. trans_and _rot_matrix.hip Edited May 25, 2015 by wateryfield Quote Link to comment Share on other sites More sharing options...
Artem Smirnov Posted May 25, 2015 Share Posted May 25, 2015 (edited) I wrote a small tool for attaching pieces to other geos. But it was done really long long ago. So dont ask me how it works and why it is done this way.)) I guess I was just young and unexperienced. Anyway it may help and it works. trans_and _rot_matrixArchiFollow.hip Edited May 25, 2015 by Artem Smirnov 2 Quote Link to comment Share on other sites More sharing options...
wateryfield Posted May 25, 2015 Author Share Posted May 25, 2015 (edited) I wrote a small tool for attaching pieces to other geos. But it was done really long long ago. So dont ask me how it works and why it is done this way.)) I guess I was just young and unexperienced. Anyway it may help and it works. Thanks for your quick reply, Smirnov. Your tool working great, and the wrangle also my expect one. I promise i will not ask anything about your cool tool. XD But if anyone have a simply one will be great. Edited May 25, 2015 by wateryfield Quote Link to comment Share on other sites More sharing options...
sadhu Posted May 27, 2015 Share Posted May 27, 2015 is this helpful ? trans_and _rot_matrix_Soln.hipnc 2 Quote Link to comment Share on other sites More sharing options...
wateryfield Posted May 27, 2015 Author Share Posted May 27, 2015 is this helpful ? Thanks, Doshi. It really helpful. But i was confused with attribvop one. Why N,up,bitangent and P can make up a matrix4, is it a simple matrix theory. And why static matrix multiply with invert transform matrix? Forgive me if the problem was horrible basic. Quote Link to comment Share on other sites More sharing options...
sadhu Posted May 28, 2015 Share Posted May 28, 2015 I am not an expert on this. I had asked similar question few day back http://forums.odforce.net/topic/22596-extracting-transformation-using-matrix/ This is what I understood so far. Experts please correct me if I am wrong. read this http://mathforum.org/library/drmath/view/69806.html 1. You need a 4x4 matrix. First three rows gives you orientation. (N, up and bitanget refer file. You can give them any name for example name them as New , upon, bit and it works just fine. Their connection sequence is not important. Make sure you make the same change for both the 4x4 matrices in the attribvop.) 2. These vectors form a reference plane for static geo and for the moving geo (these vectors get oriented as per the motion of the geo and so does the reference plane for the moving geo.) 3.about inverse matrix. I think following explanation will help you understand why we need inverse matrix. http://math.mit.edu/~gs/linearalgebra/ila0205.pdf Inverse Matrices Suppose A is a square matrix. We look for an “inverse matrix” A1 of the same size, such that A1 times A equals I . Whatever A does, A1 undoes. Their product is the identity matrix—which does nothing to a vector, so A1Ax D x. But A1 might not exist. What a matrix mostly does is to multiply a vector x. Multiplying Ax D b by A1 gives A1Ax D A1b. This is x D A1b. The product A1A is like multiplying by a number and then dividing by that number. A number has an inverse if it is not zero— matrices are more complicated and more interesting. The matrix A1 is called “A inverse.” DEFINITIO Take a any geo, create vectors using polyframe node (N,up, bitanget). Connect attribvop to it. Create 4x4 matrix from N up bittanget and P. Invert it.Multiply P by this inverted matrix. You will notice all the points of the geometry go to center of the scene. 4. Last component of 4x4 matrix gives translation (element 12 , 13 and 14 of a matrix, so P is connected in the end) 2 Quote Link to comment Share on other sites More sharing options...
