Alexey Vanzhula Posted June 1, 2015 Share Posted June 1, 2015 (edited) Hi. i want to produse acurate procedural skin (sweep, bridge). I want to get smooth trasition between two faces. Like in this image http://i.imgur.com/Z37FK9d.png I tried skin, sweep, bridge, loft, copy SOPs and it combinations, but the result is not acurate as I need. All I get is good smooth curve between faces. But how to connect faces with the same topologies but with different shapes. Any ideas?.. test scene: https://dl.dropboxusercontent.com/u/75376916/sweep.hipnc Edited June 1, 2015 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
Nico Posted June 1, 2015 Share Posted June 1, 2015 (edited) sorry... false post Edited June 1, 2015 by Nico Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted June 1, 2015 Author Share Posted June 1, 2015 (edited) ... Edited June 1, 2015 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
Skybar Posted June 1, 2015 Share Posted June 1, 2015 Bit of a brain exercise! I've never done anything like it but I thought I'd give it a go. Essentially what I do is to create a blendshape between the two faces, copy the range of the blend onto your curve and then skin it. The "resolution" is dependent on your curve, so give it a resample if it's needed. One could even adjust it so that the blendshape is not linear if one would want that, could be more interesting. This is just a quick concept I came up with and it seems to work alright, hope it helps! sweep_dv.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted June 1, 2015 Author Share Posted June 1, 2015 (edited) Skybar, nice solution. I also used blendshape for copy profile. But look at this http://i.imgur.com/MzSvppm.pngI think in this situation we need to rotate profile on curve. But I dont undestand how to mix blended shape with rotation on curve (after polyframe for example) Edited June 1, 2015 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted June 1, 2015 Author Share Posted June 1, 2015 (edited) Also i think in your example we can use simple blendshape (centered) connected to copy node. This blendshape will give blend factor from stamping (copy node). We don`t need trail, timeshift, attribcreate, attribpromote and delete SOPs. Am I right? Edited June 1, 2015 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
Skybar Posted June 1, 2015 Share Posted June 1, 2015 (edited) Yes you are absolutely right! I modified my hip a bit - modified nodes in green. I added normals to the curve which we use as "Up", and then we use the tangents as normal. The Copy SOP will use those attributes to orient the copies (I had turned it off before, it's on now), you could play around with the various template attributes to properly align the copies if it wouldn't work in another case. I suppose thats what "went wrong" in the first hip, the example was set up so nicely that it worked even if I told the Copy SOP to not orient the copies, and it looked alright. I moved the curve a bit and it seems to orient them properly now. sweep2_dv.hipncFetching info... Edited June 1, 2015 by Skybar Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted June 1, 2015 Author Share Posted June 1, 2015 (edited) Please try to rotate one of two poly islands. You can see invalid orientation... Edited June 1, 2015 by Alexey Vanzhula Quote Link to comment Share on other sites More sharing options...
Skybar Posted June 1, 2015 Share Posted June 1, 2015 Seems to works fine on my end. Anyway, my curiosity is fed and I'm quite satisfied, so I'll leave this here. Granted there may be better ways to do it, I'm not really that into modeling. Good luck! Quote Link to comment Share on other sites More sharing options...
Alexey Vanzhula Posted June 1, 2015 Author Share Posted June 1, 2015 Thanx any way!!! Quote Link to comment Share on other sites More sharing options...
