[code] tags gobble remaning text.
This post is for the website admin.
I am having a problem when I use code tags and then type followup text.
For example.
    "styles" :
            "target" : "*",
            "overrides" : {
                "material" : {
                    "name" : "`opfullpath("../shopnet1/constant")`"
                "materialParameters" : {
                    "clr" : {
                        "script" : {
                            "code" : "cvex mFn( int seed = 0; export vector out_color = {0,0,0} ) { out_color = rand(seed); }",
                            "bindings": { "seed" : "intrinsic:indexorder" }
Notice, I have not used a code tag and I can type this followup text.
Now I'll try the same thing using the code tag.
    "styles" :
            "target" : "*",
            "overrides" : {
                "material" : {
                    "clr" : {
                        "script" : {
Can you see my follow up text is now missing?
Of course it isn't doing it now, perhaps attachements have to be involved.
Here is a direct link to a post where I encountered the problem.
Edited by Atom
Ok, after another frustrating post where my text is gobbled up after I manually type "openbracket" code "closebracket" My code "open bracket" slash code "closebracket".
I believe the problem may be present on specific forums. Particularly the Rendering forum.
To reproduce this website error make a post in the Rendering forum as a reply and put some code in side a code block (not using the toolbar) and then follow that up with more non-code text. I find that my followup text just disappears and I can never type anything below the code block.
  • 5 weeks later...
Guest mantragora
Yeah, it's a problem. I learned this hard way when I wrote some answer and added couple code tags just to found out that after I posted half of the post was NOT there.
