right way to gas field to particle
Hi,guys.
I'm working with a test include pyro and pop, what i want was fetch the pyro temperature to the pop particle.
I remind gas field to particle which works great in flip. But however it seems not working with two dop object, although i modify the particle path.post-9982-0-84179600-1436847877_thumb.jp So i must be something wrong.
If someone have a same problem and give me a tip will be great.
And there is another problem, after a long study which still make me confused, which input was the right link of gas microsolver , pre-solve,velocity update,advection or sourcing. Does it depend on what type of microsolver or what you want to do with.
Thanks.
gas_field_to_particle.hip
