Texture Mix Problem
Hello Od|forum!
I ran into a little problem. I had the idea to make a procedural texture. I wanted to use ambient occlusion to blend texture A with texture B.
I used a Pointvop to blend the two textures. Two Colormaps hold the two different textures which both go into a Mix. I used the AO I already got on the floor as the Bias in the Mix.
This method kind of works. Texture B, which is green, is in the places I want it to. Texture A as well. However; both of them do not have the checkered pattern that is in the texture.
Is there someting I missed? Or is it a viewport thing?
Thanks in advance!
-Bram
Texture_Mix_Problem_01.rar
Cascading issues, all little problems that keep tripping me up too. Starting from the end and working back:
-the colormap nodes need uv's, I created a uvcoords node and attached it to the maps. Except...
-there's no uv's on your geometry, so I created a 'uv project' node just after the grid. You still won't see these on your vop network because...
-uv project nodes apply uv's to verticies, your vop network is running in point mode. I changed the mode of your vop from points to verts. Almost working, but the occlusion mix will be missing because...
-the occlusion node outputs its colour to point. I attribPromoted Cd from point to vertex.
Attached the scene, sorry I had to change the texture paths a little.
I suspect there's a better way to achieve what you're after, but this should unblock you in the short term. :)
Texture_Mix_Problem_02.hipnc
I did have uvs in my original file, but I forgot to implement them into the file I posted. But thanks a lot for your help!
I do not have a reason not to do it in SHOPs, I was wondering how to do this in a way I was familiar in and I have never made use of SHOPs.
But this is a good point to finally look into it.
