flip uv, any suggestion?
aboubakrvfx
I don`t think that will work, I think. You need to use the ID as your UV, since you are emitting continuous particles into DOPS, uv will change. The Idea is particles to carry the texture they are assigned, in that case, make sure you have particle ID. export the particle id as UV.
