Atom Posted August 3, 2015 Share Posted August 3, 2015 (edited) Hi All, I have 1920x1080 JPG sequence that starts it's frame count at 1001 frames. So the padding is like this filename.01001.jpg. The file field contains this value. $HOME/Footage/Tracking/2015-06/platte_lake_dock_shot/platte_lake_dock_shot_$F5.jpg I am overriding the frame range of the File node and the detect does correctly detect the frame range wich does not start at frame #1, however, nothing appears in the compositing view on my Windows 7 64bit with a nVidia 660GTX running H14 Apprentice. What is the trick to getting simple footage to appear in the compositor? NOTE: If I browse to a single image it does show up, just not the sequence. Edited August 6, 2015 by Atom Quote Link to comment Share on other sites More sharing options...
edward Posted August 3, 2015 Share Posted August 3, 2015 I may be wrong on this but you're using $F5 which means that your sequence starts at frame 01001, but the playbar in your picture says that your playbar is at frame 28. Maybe you want to change your global animation start frame to by 1001? Quote Link to comment Share on other sites More sharing options...
Atom Posted August 4, 2015 Author Share Posted August 4, 2015 Thanks Edward, that works. I also figured out that I could change Shift Start Frame to 1 to achieve the same effect. Quote Link to comment Share on other sites More sharing options...
