Jason Posted November 12, 2004 Share Posted November 12, 2004 Hi there, Has anyone figured out (if it's even possible to) to render Geometry inside an Object Network node? i.e, render the node: /obj/geo1/objnet1/geo1 For some reason, the Mantra/Renderman ROPs never spit out geometry into the IFD/RIB, no matter what I set in my ROP's Camera or Visible Objects fields, and no matter where I put my ROP Network. Is there something I'm missing? (Houdini 7.0.230) Quote Link to comment Share on other sites More sharing options...
Jason Posted November 12, 2004 Author Share Posted November 12, 2004 In other words, without ObjectMerging back in to the /obj object root, I want to render: /obj/geo1/objnet1/geo2 in this file: render_geo2_please.hip.gz Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted November 12, 2004 Share Posted November 12, 2004 Hey Jason, I think you've found a bug... a similar thing used to happen with lights inside an object network, but that's fixed now. It basically doesn't descend recursively into each top-level OP... sees your null and decides there's nothing to render I got it to work by objmerging up one level (merging /obj/geo1/objnet1/geo2 at the /obj/geo1 level, replacing the null); but I know that doesn't help. Bug, I say. Quote Link to comment Share on other sites More sharing options...
Jason Posted November 13, 2004 Author Share Posted November 13, 2004 Bug, I say. 14901[/snapback] Yea, must be. Quote Link to comment Share on other sites More sharing options...
deecue Posted June 17, 2011 Share Posted June 17, 2011 fast forward to 2011.. has anyone ever seen this work? objects or even lights? p.s. hi everybody! 1 Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted June 21, 2013 Share Posted June 21, 2013 Reviving an old thread, sorry! But it's for a good reason. I found this thread by searching because I was running into the same issue. I sent an email to SESI and got a quick response. For anyone else that runs into this in the future see below. You will need to put a camera inside your object network. The scene geometry is dependent on which object network the camera is contained within. 2 Quote Link to comment Share on other sites More sharing options...
