Atom Posted August 25, 2015 Share Posted August 25, 2015 (edited) Hi All, I have a smoke sim that looks good in my viewport. I want to get a quick OpenGL render of it. However, when I use an OpenGL ROP to export the image sequence I see the progress dialog briefly appear at frame #1 then the dialog just diappears and I get no files on my disk. I don't get any error message either. Can the OpenGL ROP even render smoke? It seems like it should be able to because I can see it in the viewport? Is there another way to issue a viewport render? Edited November 12, 2015 by Atom Quote Link to comment Share on other sites More sharing options...
cojoMan Posted August 28, 2015 Share Posted August 28, 2015 for one - yest it can - I tried the openGL rop in a scene with a pop sys, geo, and pyro, and it rendered them all the bad thing is it does not replicate the "viewport look" precisely, like flipbook does - so it sees your smoke, but without lighting or color detail...just a plain gray smoke - if you can get it to work, please update - I need it as well... Quote Link to comment Share on other sites More sharing options...
Atom Posted August 28, 2015 Author Share Posted August 28, 2015 (edited) One thing I did discover is that the OpenGL ROP can render with the Display Flag or the Render Flag. This means you can actually render out some of the various visualization styles. Still playing around with this though. The DOP Import also has some controls for mapping various fields/attributes using various styles such as smoke etc... By exporting temperature and density as separate OpenGL render passes I can then composite them together for a better overall effect compared to just cranking the entire thing out as smoke from the OpenGL ROP. Here is the density attribute ADDED to the temperature attribute in After Effects. ap_atom_logo_smoke_1b.hipnc Edited August 28, 2015 by Atom 1 Quote Link to comment Share on other sites More sharing options...
Atom Posted November 12, 2015 Author Share Posted November 12, 2015 cojoMan, I think I found a way to get color into smoke and still render it using the OpenGL rop. Inside the pyro_import add a volume visualization node after the import_pyrofields. Move the display flag to the volume visualization node. With the visualization node selected switch to the Emissions tab and set Emission Scale to 1, Emission Field to "temperature", Emission Color Field to "heat", for Mode choose preset Black Body. This will cause the two attributes, heat and temperature to be mapped to the emissions channel. Meanwhile, move to the out network and select the OpenGL rop. On the Scene tab choose Display Flag for the SOP source instead of the default Render Flag. Because we setup the visualization node to map the attributes into a valid emission channel, the OpenGL rop can make use of that information and renders the color. I have attached a demo file with the visualization node already setup. ap_sphere_fireball.hipnc 1 Quote Link to comment Share on other sites More sharing options...
cojoMan Posted November 12, 2015 Share Posted November 12, 2015 you - are a genius ! yes, I guess it makes sense...the opengl takes care of volume display only, and doesn't now how to interpret the fields + we are only seeing them in the viewport as is BECAUSE of a vis op on the pyro object..but why that wouldn't be captured by the opengl directly since the flipbook gets them for free, and you'd have to reinvent the wheel like this....anyway - it works ! great job. Quote Link to comment Share on other sites More sharing options...
