Juraj Posted September 23, 2015 Share Posted September 23, 2015 Hello, just a quick question. I have deforming fractured object and I want to release it's pieces gradually. One possible way to do that is: create RBD Packed Object with Overwrite Attributes from SOP enabled then adjust active and deforming attributes in SOPs This way works well but I noticed that even when all pieces are static simulation runs slowly. Faster way seems to use Static Object to refference to static pieces. And in SOPs delete activated pieces and these activated pieces add into empty RBD Packed Object. It is faster as Bullet doesn't seem to simulate Static Object and use it only as collider. When I do the same with Attributes Overwrite way it is much slower. Am I missing something or it is normal? First solution seems to be more elegant and simple. But slower unfortunately. Thanks, Juraj Quote Link to comment Share on other sites More sharing options...
Juraj Posted September 23, 2015 Author Share Posted September 23, 2015 Also one more question - how can I "repack" rbd geometry in Sop Solver ? I mean unpacking geometry and packing it back. Quote Link to comment Share on other sites More sharing options...
anim Posted September 25, 2015 Share Posted September 25, 2015 it's better if you provide example where it's slower be aware that by enabling override attributes you are forcing input SOPs to cook every frame just to figure out the values of active, deforming and animated attribs so if your input geo is slow to recompute then that may be the problem you are seeing Quote Link to comment Share on other sites More sharing options...
Juraj Posted September 28, 2015 Author Share Posted September 28, 2015 Hi thank you for your reply. I've assembled example scene with notes. example_scene_forum.hipnc Quote Link to comment Share on other sites More sharing options...
anim Posted September 29, 2015 Share Posted September 29, 2015 (edited) well, that's quite opposite from what you've described in first post sim_1 is faster and it's using Override Attributes From SOPs that makes sense as in your file only thing it needs to do is update those attributes since your SOP input cooks very fast you probably wanted to turn on deforming using i@deforming = !i@active; then it gets actually slower than sim_2 which is as well using deforming static collider the time difference may be due to the method of creating collision shapes while in both cases it needs to recreate them every timestep, in sim_2 it's using Create Convex Hull per Set of Connected Primitives, which actually creates one dop object with multiple collision shapes, which seems to be faster than creating collision shapes for individual independent objects in sim_1 as for repacking, that's very tricky subject here is very very simple way of repacking probably not very safe as the transform and pivot of the original prim is still not preserved which is doable as well, just maybe after some sleep the point of your scene not working was that you were destroying all attribs on your packed prims repack_basic.hipnc Edited September 29, 2015 by anim Quote Link to comment Share on other sites More sharing options...
Juraj Posted September 29, 2015 Author Share Posted September 29, 2015 Hi I'm a little bit confused here. Ins't transform represented by P attribute and pivot by pivot attribute? If I will not edit geometry shape but only change color it isn't necessary to recompute pivot, is it? Also I was wondering whether pivot and center of mass are the same thing. Quote Link to comment Share on other sites More sharing options...
anim Posted September 29, 2015 Share Posted September 29, 2015 (edited) no, it's represented by P and transform prim intrinsic and pivot prim intrinsic, which you will loose by unpacking, and would need to correctly setup for newly packed prims so that they are the same Edited September 29, 2015 by anim Quote Link to comment Share on other sites More sharing options...
Juraj Posted September 29, 2015 Author Share Posted September 29, 2015 (edited) Thanks for explanation. I just found out that I missed this whole "intrinsic" concept. I will have to look into it because now I don't understand difference between attributes and intrinsics. EDIT: If you know about learning resources about intrinsics please post it here I couldn't find explanation in docs. Edited September 29, 2015 by Juraj Tomori Quote Link to comment Share on other sites More sharing options...
