Modify animation [SOLVED]
lazza79
Hi guys,
I am still working on my boat and I would like to alter the animation.
In the detail, I would like to "rotate" the boat a little faster when it hits a wave, so I think that the better way it would be to alter the "x" rotation (in orange).
post-14285-0-84896600-1443534573_thumb.p
I would like to obtain the result you see in white.
I think the way is to alter the channel values in the CHOP network but I don't know which function to apply or, if it is possible to manually alter the lines.
I tried to use the "math" operator and multiply the values for 1.5 but it only increases the degrees of rotation and it's not what I want to achieve.
Imagine a boat that gets a wave: it rotates up very fast, then "rests" and then when it hits the sea inverts the rotation and then rests again...
Since my animation was created by the projection of the boat to the sea waves (with some filters and lags), it is too linear...
Thank you for your help.
Cheers!
Lazza79
Edited by lazza79
Thank you Bluciensky,
unfortunately that was not the result I was hoping for (maybe i didn't explain myself correctly)
By applying the clamp I actually achieve less rotation and all the cycle will level up to the same value.
Even amplifying the "wave", clamping it and filtering it, I will obtain almost the same result.
Basically, what I would like to achieve is that when the waves is goin up or down, the slope is more "vertical" but the distance between the apex should remain the same, as it should the amplitude.
Cheers!
Lazza79
