hda's and opparm
Marc
Hey all
So I was under the impression that you could use the opparm expression in an hda? Well, let me rephrase that, it seems like you can, but only if the hda is unlocked, which seems to defeat the purpose.
I must be missing something..
What I have is a ROP inside my digital asset with this opparm expression :
opparm -c `oppwf()`/bakeout_points/starting_points execute
Works great when its unlocked, doesn't work at all when its locked. Is it possible to do this things? And if not, then why not?
Thanks
M
P.S. My first foray into building a serious digital asset and its a little frustrating, I must say.
You can render a ROP inside of the subnet if you:
*) use the render command instead of opparming the buttonpress: "render bakeout_points/starting_points"
-or
*) promote the render button to the HDA top level. i havne't done this but i'm sure its possible.
That's what I was trying to do with the opparm (promote the button).
From the help :
...The fourth form executes any callbacks associated with a
parameter. If the parameter is a button which executes a
callback, it is possible to use the third form to invoke the
function. Examples of these type of buttons are in the creep
SOP (initialize), and many render output drivers (the render
buttons).
eg. opparm -c /out/mantra1 execute
The problem with doing it the first way is that my ROP is an hda too, so I guess the 'render' button isn't recognised internally as a render button. Who knows.... it definitely doesn't work though.
M
sure, but you can't opparm something if the network is locked. Unless this one is different in some way.
M
P.S. I also just learnt not to duplicate parameters inside the dialog editing thingy. It changes all your channel references to the new duplicated names (for some reason).
argh.
Don't try and set it up manually, in the type properties manager click on the plus button next to "create new" and navigate to the render button. This will then set up the link automatically. Only time I've had problems with this is in cops, but I think that might be fixed in the latest build.
ok I'm returning to this topic, since it was meant to address my specific problem while the other one was more of a generic HDA's improvement discussion.
So I think I've figured out why my render button isn't working. I don't know why it works when its unlocked and doesn't work when it's locked... but perhaps its related.
So this is my basic setup.
I have an HDA which will do all of my geometry deformations. Inside that is a ROP network which will be responsible for writing out the relevant geometry to disk.
So inside that ROP network are two ROP's, one is a geometry output node and the other is our custom output node which calls a bunch of scripts to add everything to the database and put the geometry in the correct place on the shottree. And it references the geometry ROP.
I think the problem lies in the fact that this custom node is an HDA too, so inside it is a bunch of networks which make it work (chop, rop etc.).
It seems like my top level dialog script can access the 'execute' button in my first ROP subnet and that's all. Sadly I need to go down another level to the second ROP subnet and hit that execute button. I have a feeling its linked to the 'Forbid Linking Parameters from Outside this Subnet' toggle but I'm not sure. If I turn that off then I get a crapload of warnings and it still ends up not working, so it may not be the reason.
Does this make sense? It's well nigh impossible to get an example file out without sending the custom ROP node...
Thanks
Marc
