cwalrus Posted October 19, 2015 Share Posted October 19, 2015 Hi - i love the wet sand look and ability to adjust clumpiness, but that does not exist with the standard particle systems. I have a good particle animation with a standard POPnet and I want to add clumping to the particles now... is that possible? thanks! cameron Quote Link to comment Share on other sites More sharing options...
cwalrus Posted October 27, 2015 Author Share Posted October 27, 2015 Bumping myself since this is a cool question. 1 Quote Link to comment Share on other sites More sharing options...
mestela Posted October 28, 2015 Share Posted October 28, 2015 (edited) Dunno about your specific needs, but try adding a pop grains pop into your setup, set clumping weight and stiffness lowish. See the attached scene, toggle the popgrains node to see the effect. pop_clump.hip click to play Edited October 28, 2015 by mestela 1 Quote Link to comment Share on other sites More sharing options...
cwalrus Posted October 29, 2015 Author Share Posted October 29, 2015 Wow - but how did you get your render? When I open your scene file it appears as though you have only dropped a POP grains node into the chain, and nothing renders. In default 'wet sand' sims, there's usually a new source node for the popgrains that has grains source, wetsand, etc. Also in the PopNetwork there is a GrainSprite and GrainColor... what version are you using? thanks mate Quote Link to comment Share on other sites More sharing options...
Jason Posted October 29, 2015 Share Posted October 29, 2015 Try POP Interact with a negative force? 1 Quote Link to comment Share on other sites More sharing options...
mestela Posted October 29, 2015 Share Posted October 29, 2015 (edited) The sprites, grain create etc are all useful, but not necessary if all you want are the basic pop grain forces. Its exposed as a force like other pop forces. I suspect Jason's setup might be more efficient though. I'm using H15. Edited October 29, 2015 by mestela Quote Link to comment Share on other sites More sharing options...
