AskardBr Posted November 3, 2015 Share Posted November 3, 2015 Hi, I`m currently doing an ocean scene on houdini Indie and I`m having some problems with the "export to texture" part. If I have a resolution exponent of 10, my displacement maps will be 1024 x 1024. If I increase it to 12 for the amount of details that I need, the maps will be 4096 x 4096. However, if the maps are set to this big, when I click Render ( in the export to texture tab), nothing happens. I only get the displacement maps exported if they are 1024 x 1024. Any reasons why? Is there any way to solve this? Thanks Quote Link to comment Share on other sites More sharing options...
Jason Posted November 3, 2015 Share Posted November 3, 2015 I might be wrong, but I thought you could render RAT format files at high resolutions without issues, for this exact reason. Well, with Mantra... But I suppose this is coming through COPS, so you may be out of luck... Quote Link to comment Share on other sites More sharing options...
sebkaine Posted November 3, 2015 Share Posted November 3, 2015 i'm afraid you're stuck to 1080*1080 in indie but not 100% sure. however to work with textures procedurally and be able to bake a 4096*4096 i will investigate substance designer. you have a indie version with very attractive formula. and that might be the tool you need for proceduralism / bake of 4K texture. Quote Link to comment Share on other sites More sharing options...
acey195 Posted November 3, 2015 Share Posted November 3, 2015 or you could just render 4 textures and stitch them together, if you only have to do this occasionally Quote Link to comment Share on other sites More sharing options...
Whatsinaname Posted November 3, 2015 Share Posted November 3, 2015 If I remember correctly, it was possible to set the file format of the texture node to an equivalent nc (non- commercial) version, so you could create larger textures. Should be anywhere on the forum, just search for it. Quote Link to comment Share on other sites More sharing options...
Mandrake0 Posted November 3, 2015 Share Posted November 3, 2015 on the indie version you have to change the setup: Node Ocean_preview > Export to Texture > Save Current Frame Node Ocean_render > Export to Texture > Save Current Frame so you get the Still image Unlimited Resolution otherwise you get always the 1080p Limit Quote Link to comment Share on other sites More sharing options...
