zarti Posted November 8, 2015 Share Posted November 8, 2015 hello everyone , i have simulated and stored 350 .sim files ( ~450 Mb each ) when i switch the DOP network in sim-play-mode , only first 200 frames are displayed . not any other beyond that . - can someone suggest to me how to deal with this ? thanks in advance ! .cheers Quote Link to comment Share on other sites More sharing options...
Sankar Kumar Posted November 8, 2015 Share Posted November 8, 2015 (edited) Did you try saving "name.$F3.bgeo" and test load using "file sop" also you may try loading those .sim files using "file SOP" (To check the simulation) Edited November 8, 2015 by Sankar Kumar 1 Quote Link to comment Share on other sites More sharing options...
zarti Posted November 9, 2015 Author Share Posted November 9, 2015 .. also you may try loading those .sim files using "file SOP" (To check the simulation) thank you very much , Sankar Kumar ! esp. thank you for posting on weekend , while mine wasnt such =) .. and so thats why i only could now "thank you" .. now back into ` technical ` aspect : the File_SOP gave me exactly what i wanted; it could read the .sim file format and i didnt knew that ( at least filetype filters of File_SOP `told me so` ) . before calculating the simulation i set the timeStep to ~0.3 . i wasnt sure how long the seq would be needed for me and also thought wd be better to have a 3xfinner calculated version . the problem i had was that while DOP_net was in playback mode it played a lot faster than 1/3rd . the File_SOP played it immediately the full sim as i expected . maybe thats explained in Hou_Docs .. but my rush , lack of exp. and the high-rate-compresion-of-knowledge of Hou_Docus have had for me in past .. make me Appreciate tremendously the value of houdini community . the bolded section in line above and this small suggestion below : - to add an playback_speed control on DOP_net while thats in playsim mode ( since data is there ) .. Go to SESI ! .cheers Quote Link to comment Share on other sites More sharing options...
