GAS Posted November 22, 2015 Share Posted November 22, 2015 how I can do that with vop ? Quote Link to comment Share on other sites More sharing options...
hatrick Posted November 22, 2015 Share Posted November 22, 2015 (edited) hey, there is a thread in the general questions sections named "learning vops", i'm not 100% shure if your specific question is discussed there but maybe you should take a look. cheers here you can find an example how to build a helix ore spiral with vops, maybe a good starting point for you problem http://forums.odforce.net/topic/12669-how-to-create-a-spiral-curve-in-sop/ Edited November 22, 2015 by hatrick Quote Link to comment Share on other sites More sharing options...
mestela Posted November 22, 2015 Share Posted November 22, 2015 In a attrib wrangle: @N = cross(@P, {0,1,0}); @N = normalize(@N); A cross product gives you a vector which is perpendicular to 2 other vectors. Here we treat @P as one vector (ie, an arrow from (0,0,0) to each point), the y axis as another vector (0,1,0), the cross product gives you a vector that orbits around the y-axis. This vector will get bigger the further away @P is from the origin, so you run a normalize() to make it of standard length. 2 Quote Link to comment Share on other sites More sharing options...
GAS Posted November 23, 2015 Author Share Posted November 23, 2015 In a attrib wrangle: @N = cross(@P, {0,1,0}); @N = normalize(@N); A cross product gives you a vector which is perpendicular to 2 other vectors. Here we treat @P as one vector (ie, an arrow from (0,0,0) to each point), the y axis as another vector (0,1,0), the cross product gives you a vector that orbits around the y-axis. This vector will get bigger the further away @P is from the origin, so you run a normalize() to make it of standard length. thankxxxxxxxxxxxxxxxxxxxxx Quote Link to comment Share on other sites More sharing options...
fuat Posted November 25, 2015 Share Posted November 25, 2015 (edited) in VOPS:1. plug your grid into an AttributeVOP´s first input. Dive inside. 2. from your globals, get P 3. connect it to a cross product node´s upper input (or lower to change rotation direction) 4. create a constant node of type vector, set values to 0,1,0 and plug into lower input of the cross product (or change input order if you wann rotate your normals the other way around, see above) 5. plug the output of your cross into a normalize 6. plus that into globals "N" done. keep in mind that this will of course change/screw your shading, since the normals are used for shading hth fuat Edited November 25, 2015 by fuat Quote Link to comment Share on other sites More sharing options...
