mosssi Posted December 13, 2015 Share Posted December 13, 2015 Hi all I assume you already see Lee Griggs artworks produced by Xgen. If not this is the link: http://www.leegriggs.com/335056/3779154/home/xgen-rendered-with-arnold-for-maya I thinking about a way to reproduce this nice effects and animating them in Houdini but with copy sop its really heavy to work and because I'm not experienced enough in H, I don't know an alternative way to do that. I'm pretty familiar with Xgen and I can do this in Maya but I think Houdini is capable of doing something similar. So what's your opinion? Thanks Quote Link to comment Share on other sites More sharing options...
Stalkerx777 Posted December 13, 2015 Share Posted December 13, 2015 http://forums.odforce.net/topic/20716-unofficial-challenge-boxified-images/ Quote Link to comment Share on other sites More sharing options...
mosssi Posted December 14, 2015 Author Share Posted December 14, 2015 On 12/13/2015 at 5:42 PM, Stalkerx777 said: http://forums.odforce.net/topic/20716-unofficial-challenge-boxified-images/ Thanks Alexey, I Didn't search the artist name so I didn't find the topic. but the copy sop performance is very behind Xgen Quote Link to comment Share on other sites More sharing options...
f1480187 Posted December 15, 2015 Share Posted December 15, 2015 (edited) Copy before animation. Manipulate data using VEX nodes. Actually, you can get rid of Copy SOP completely, but it is fast when used properly. boxes.hipncFetching info... Edited December 16, 2015 by f1480187 Quote Link to comment Share on other sites More sharing options...
mosssi Posted December 15, 2015 Author Share Posted December 15, 2015 On 12/15/2015 at 3:43 AM, f1480187 said: Copy before animation. Manipulate data using VEX nodes. Actually, you can get rid of Copy SOP completely, but it is fast when used properly. That's what I'm talking about. Thank you man. you didn't even use packed primitives but its fast enough, I assume the stamp function is the lazy one. also thanks for the example. Quote Link to comment Share on other sites More sharing options...
Marc Posted December 15, 2015 Share Posted December 15, 2015 Stamp would sacrifice speed for controllability. There are multiple ways to do this in Houdini right now, so you'll need to pick the solution that matches what you need to do. Since you're new, I'd avoid stamping for the time being Quote Link to comment Share on other sites More sharing options...
mosssi Posted December 16, 2015 Author Share Posted December 16, 2015 On 12/15/2015 at 8:09 PM, Marc said: Stamp would sacrifice speed for controllability. There are multiple ways to do this in Houdini right now, so you'll need to pick the solution that matches what you need to do. Since you're new, I'd avoid stamping for the time being Thanks Marc Just for curiosity, can you please explain briefly about any possible method. I'm sure I can dig into them. Quote Link to comment Share on other sites More sharing options...
Solitude Posted December 17, 2015 Share Posted December 17, 2015 You can use certain attributes on a set of template points to transform the geometry that you want to copy in the copy sop. I would do a packed box with the botom of the box at 0,0,0, and do a packed prim copied onto the points. The points can have a scale attribute that controls the height. The scale attribute (vector) can controll x,y,z scale. Pscale can then control uniform scale if you want. To get scale on the points, you can use vops/vex or attribfrom map... whatever you need. Quote Link to comment Share on other sites More sharing options...
mosssi Posted December 17, 2015 Author Share Posted December 17, 2015 On 12/17/2015 at 2:52 AM, Solitude said: You can use certain attributes on a set of template points Thank you for your attention. yes it seems fast and manageable and probably what I just need for this. but is it true that copy sop only apply scale, pscale and orbit attributes of template points automatically and for other attributes we need stamp function again? Quote Link to comment Share on other sites More sharing options...
Solitude Posted December 17, 2015 Share Posted December 17, 2015 You can copy any attribute from the template point onto the packed prims, such as color. You can then reference those packed prim attributes in a shader as well. This differs from attributes you've saved on to the geometry itself. The new shaders have an option for using packed prim color as well now. For transforms check this: http://www.sidefx.com/docs/houdini15.0/copy/instanceattrs Quote Link to comment Share on other sites More sharing options...
mosssi Posted December 18, 2015 Author Share Posted December 18, 2015 Thanks Solitude, this is helping me a lot. Quote Link to comment Share on other sites More sharing options...
