"Unsnatchable" operations with HScript
hoknamahn
Is it possible to carry out a similar series of operations with HScript?
1. Detach handle
2. Align with world axes
3. Attach handle
I just want to assign alignment of the object's axes on the hotkey.
Second question: how to bind toggle of one operator to toggle of other operator (with HScript). In this case I can't use chadd/chkey. Any solutions?
No, I want to assign a several operations to one hotkey.
15914[/snapback]
There is a long-standing RFE with SESI to allow us to bind hscript files to hotkeys. No movement on that one, I'm afraid. The only keys you can bind are the F-keys - which are mostly used up for Desks. You might be able to bind F7-F12, though.
15922[/snapback]
In principle it is not important, what key will be hot. Another is important - do appear operations Align with world axes, Project pivot onto c-plane, Gimbal mode, Display handle etc. or Change selection mode by operations, for which there are no equivalents in the form of the HScript commands?
