Conform Object To Surface?
Atom
Hi All,
I have an Illustrator design that I have copied along a line to make 3 copies. I have extruded it and deformed it along a circle to get the final layout in the general area of the surface I want to project on to.
The target geometry is a vase with a surface pattern. I want the design to follow the contours of the vase.
I have tried the RaySOP but it loses my extrusion when I apply transform points.
Here is the look without Transform Points:
post-12295-0-11842400-1453135811_thumb.j
Here is the look with Transform Points:
post-12295-0-69636200-1453135844_thumb.j
Is there any way to project an extruded object on to another object and not have it go flat?
I still want to maintain the extrusion height even though the design is conforming to a surface?
ap_design_over_surface_1a.hipncFetching info...
Edited by Atom
Thanks Yader I guess I could try it that way.
It does work but I had to add a SubDivision SOP for the target surface and use OpenSubDiv Loop Algorithm to create enough point distribution to cover the smaller thin parts of the design I am conforming. The next step is to make this water tight for 3D printing.
What nodes do I add to prepare for .STL output?
Is that step just convert to VDB and back?
ap_design_over_surface_1b.hipncFetching info...
post-12295-0-23440400-1453142756_thumb.j
Edited by Atom
