whitewater - generic questions
cily
A couple of version about the whitewater in H
PART A:
cached out the whitewater, I have the 3 group foam spray and bubbles,
to see in viewport the result as in the dop lvl I'm running this wrangler
if (inpointgroup(0,'foam', @ptnum) == 1) {
    @Cd = {0,0,.5};
if (inpointgroup(0,'bubbles', @ptnum) == 1) {
    @Cd = {.5,0,0};
if (inpointgroup(0,'spray', @ptnum) == 1) {
    @Cd = {0,.5,0};    }
folloved by a vop with lenght and fit to manage the luminance based on velocity,
question
1) there are a faster way human friendly to have this result?
2) vex doesn't have elif statemnt?
PART B:
whitwater solver is an asset using pop Solver,
anyone tried to switch it in Flip? just to have more kernel structure of the 'fluid'. - other sw are using flip also for whitewater .
thanks
S.
there is an else in vex, not no elif.
for a more straightforward approach, i would suggest you use the groups in the group field of a color sop (or three color sops) to set your colors.
you can also do "@group_XXX" to check ownership of a group.  so "if (@group_foam == 1)" can replace the whole "inpointgroup()" thing.
