Hi all,
I've run a ground while building a set-up for creating centroid points from surface prims, animating/deforming the points, then applying the animation back to the prims via a matching prim_id or prim group_id.
The prims in question are separated via facet and partition sops, and all their numbers do match/correspond to the animated/deforming point numbers.
The lookdev would be sections of a surface dissolving/evolving via the incoming point motion.
Something roughly in this direction:
I'm just not sure how best to go about copying the motion back to the prims.
After some heavy googling, I've been looking at forEach and copy_stamping as an approach but no luck so far.
Have a look at the attached hip.
Any help would be appreciated.
post-9537-0-88532200-1454341723_thumb.jp
prim_id_or_group_id__to_follow_point_id_motion.hipFetching info...
