amin.khormaei Posted February 5, 2016 Share Posted February 5, 2016 as you can see in the picture that i attached , i wanna emit the pyro with the red color i painted on the plane . i set the value to $CR and i'm gonna use this attribute for source volume node, but i can't find any attributes in source volume node to use the attribute create node, am i wrong to do this ? is there other ways to do this? please help me best regards amin khormaei Quote Link to comment Share on other sites More sharing options...
Atom Posted February 5, 2016 Share Posted February 5, 2016 I think you need one more step. You need to emit particles from the area then you can use the shelf tool to create pyro from the particles. Search around for emit particles from image or something similar. Quote Link to comment Share on other sites More sharing options...
Farmfield Posted February 5, 2016 Share Posted February 5, 2016 (edited) Atom's idea is one solution, but you can also set it up to emit from the mesh and do a delete based on color value - that would also work on an animated texture, like in this setup... tex.flames.v1.hip Edited February 6, 2016 by Farmfield Quote Link to comment Share on other sites More sharing options...
amin.khormaei Posted February 5, 2016 Author Share Posted February 5, 2016 thank you all , actually i connect the plane to the paint node and afterward, turned on the override color in paint node next i connect a pop network to the paint node , and i set the emission attribute to Cd and set the fluid method to set stamp point Quote Link to comment Share on other sites More sharing options...
DanBode Posted February 6, 2016 Share Posted February 6, 2016 thank you all , actually i connect the plane to the paint node and afterward, turned on the override color in paint node next i connect a pop network to the paint node , and i set the emission attribute to Cd and set the fluid method to set stamp point This is good time to use the scatter sop! It's way easier than dealing with particles and just throws a bunch of points on your geo, can be based on attrib too! Quote Link to comment Share on other sites More sharing options...
DanBode Posted February 6, 2016 Share Posted February 6, 2016 O_O I finally did it. after 7 years I've hit 100 posts. It's like I'm a real Houdini artist now! Quote Link to comment Share on other sites More sharing options...
