poly modeling - cruves extrude [SOLVED]
6ril
I've started a thread in rendering about a shadow pb : http://forums.odforce.net/topic/25244-wrong-shadow/
seems like the pb is in the model, so I'm looking for modelling help here.
1- what is wrong with how I made the wall ? cookied curves + ployextrude.
Is there a better way ? A better way to combine curves maybe ?
2- I need the opposite wall, with the copy SOP I made a reflected copy (scale -1 on 2 axis)
The resulting geo is all normals inside, and still have the shadow problem. Renders as weird as the original wall.
3- What would be the best way to control/flip my normals? I saw somewhere a simple VEX line in a pointwrangle or attribwrangler, but I can figure out where I saw that.
The reverse node doesn't seem to reflect the change in the viewport (but affect the render).
Thanks for your time, on any or all points. <- could write that in vex?
here is the hip file:
shadow-pb.hipnc
Edited by 6ril
