cwalrus Posted March 8, 2016 Share Posted March 8, 2016 I'm I correct in assuming this is not possible usingFan Force? Blowing the smoke from a pyro sim around? How do you append a simple Fan or something similar to a Pyro sim? thanks! Quote Link to comment Share on other sites More sharing options...
fathom Posted March 8, 2016 Share Posted March 8, 2016 yeah, this is where dops kind of become a bit convoluted. it seems that each object/solver type has a different way to introduce forces. for a pyro, if you need something more than just a simple constant wind direction, then you might want to create a velocity field and then use a volume source to add/mix with your current velocities. if it's just a constant direction, there's a "wind tunnel" field on your smoke object dop. Quote Link to comment Share on other sites More sharing options...
Atom Posted March 8, 2016 Share Posted March 8, 2016 (edited) You can put a wind force after the pyro node. Or simply pick a Bouancy Direction on the solver itself. Don't forget to play with the Shape tab, Turbulence is your friend. Edited March 8, 2016 by Atom Quote Link to comment Share on other sites More sharing options...
cwalrus Posted March 8, 2016 Author Share Posted March 8, 2016 Ok - So If I wanted an animated fan affecting the velocity of my pyro, how would I create that? I know how to source it in my pyro sim - just don't know how to create, other than setting up a Particle sim and advecting the Pyro with it, which seems like a lot of effort for a simple thing...? Quote Link to comment Share on other sites More sharing options...
cwalrus Posted March 8, 2016 Author Share Posted March 8, 2016 Just saw Atom's post - does that mean I can put a Fan Force after the pyro node? EDIT: YES YOU CAN! i was putting it before it... but that works great! Thanks Atom! Quote Link to comment Share on other sites More sharing options...
javidial Posted August 17, 2017 Share Posted August 17, 2017 (edited) I'm also trying to apply a wind force. It's very tricky. I have to apply a lot of "force per unit area" to make it work in my scene. Edited August 17, 2017 by javidial Quote Link to comment Share on other sites More sharing options...
cwalrus Posted August 17, 2017 Author Share Posted August 17, 2017 (edited) You can apply a fan force mode after the Pyro solver. You will see the guide for the node in the scene and it is very intuitive after that. Crank the wind force up until you see your Pyro's behavior changing. Then turn it down a little bit to your liking and play with the other settings. Remember that it creates the node at 0 0 0 Edited August 17, 2017 by cwalrus Quote Link to comment Share on other sites More sharing options...
jaymz.miller Posted August 20, 2021 Share Posted August 20, 2021 Thanks for this - it was super helpful! I know this is an old thread, but I was wondering if you managed to get the fan force to follow an object or anything like that? I have an alembic cache, but can't for the life of me figure out how to make the fan force follow it. I've used the parent function to get the emitter to follow the alembic, but I so no way to get the fan to do the same thing. Cheers for any tips! J Quote Link to comment Share on other sites More sharing options...
cwalrus Posted September 19, 2021 Author Share Posted September 19, 2021 @jaymz.miller Do you still need this? sorry for late reply Quote Link to comment Share on other sites More sharing options...
