Manipulate objects as copies?
Hamp
Hi all!
I was wondering - is it possible to transform regular objects in the same fashion as instances on a copy object?
For example control their scale with pscale or move them around so that when scaling they simply move.
If I was to create a point at the centroid of each object - is it possible to use these points to drive the original geometry for example?
Kr,
Hamp
Thanks, nifty to move the objects!
However: how do I manipulate scale, rotation and translation on a per packed primitive basis?
[Edit] Nevermind, solved the translation, looking into scale and rotation..
[Edit 2] Got it, I need to manipulate the primitive intrinsics somehow... any clues?
Edited by Hamp
  • 3 weeks later...
