Offset random primitives in the x axis
Jimbo55
Simplest way to access a specific axis of a vector is to break it out using a vector to float piped into a float to vector, then using an add on the first connection between them, you'll only affect X.
If you want to change it randomly, just add a random and pipe the primnum into it, then into a fit range to control the min/max and onto the above mentioned add. :)
