Shalinar Posted April 27, 2016 Share Posted April 27, 2016 (edited) Hey guys, first post here. I'm extremely noob at Houdini and I've got a very basic question. I've got a particle system going, and after the POPs system in the Source Particles SOP it creates, I'm trying to use the Y position of each particle to drive a Blend Sequence that is copied onto the particles with a Copy SOP. What I haven't been able to find is how to query the Y position of my particles. I can find their positions with the Geometry Spreadsheet, but the name of the attribute it gives me is "P[y]", and typing that into an expression doesn't seem to work. I had thought it might be "@P.y" but that errors out as well. I think one of the problems is that I'm not telling Houdini WHAT to find the Y position of. But again, not sure how to find that. I've googled and did a cursory search of the forums here but all the posts I've found are way more advanced than this simple thing I'm trying to find Can you fine gentlemen/ladies point me in the right direction to find how to query this sort of basic data? wk2_copy.hipnc Edited April 27, 2016 by Shalinar to attach file Quote Link to comment Share on other sites More sharing options...
woodenduck Posted April 27, 2016 Share Posted April 27, 2016 It sounds like you might be confusing Houdini expressions with vex. @P.y will give you the y position of the current point. But if you are using Houdini expressions you may want to look at the point expression which would be something like point("path_to_node", $PT, "P", 1) or in some cases the $TY local variable will work. To some extent local variables have been replaced by vex, but I can never remember exactly where. If you can upload a hip file you might get more answers as people can see exactly what you are trying to achieve and give you a practical example. Quote Link to comment Share on other sites More sharing options...
Shalinar Posted April 27, 2016 Author Share Posted April 27, 2016 Hey thank you for the reply! $TY was indeed what I needed. You are right, I was most likely confusing Houdini Expressions with VEX... What is the difference? That point expression was cool but exhelp seemed to indicate that it was used for geometry whereas I was trying to query the Y values of my particles. Even though I believe I've got it worked out (for what I need), I'll go ahead and upload the hip file, for posterity. I'll dig into the help files to learn more about local variables. Thanks again for the help! Quote Link to comment Share on other sites More sharing options...
Atom Posted April 27, 2016 Share Posted April 27, 2016 What is the difference? Houdini supports three languages, HScript, Python and VEX. The difference is syntax. Hscript and Python are not multi-threaded, but VEX is multi-threaded. Quote Link to comment Share on other sites More sharing options...
