True Displacement Disabled vs Bump
in terms of what they do, no
they both just alter the normals, you can however use both and bump/normal map will be applied on top of displacement normals, since internally, exported displacement normal alters surface normal and that is later altered with bump/normal  map
Edited by anim
  • Like 2
