tweekskratch Posted May 16, 2016 Share Posted May 16, 2016 Hey all, I'm looking to emit some steam from the surface of a coffee mug. I'm a newbie so any help or direction would be awesome. Thanks! JL Quote Link to comment Share on other sites More sharing options...
kleer001 Posted May 16, 2016 Share Posted May 16, 2016 Easy peasy. Just select your mug and hit the Whispy Smoke in the Pyro shelf. Vioa! Play with the disipation parameter to make the smoke die faster and the turbulence for, well, turbulence. Also post your results Quote Link to comment Share on other sites More sharing options...
tweekskratch Posted May 17, 2016 Author Share Posted May 17, 2016 On 5/16/2016 at 9:03 PM, kleer001 said: Easy peasy. Just select your mug and hit the Whispy Smoke in the Pyro shelf. Vioa! Play with the disipation parameter to make the smoke die faster and the turbulence for, well, turbulence. Also post your results Expand Thanks so much! That's a great start for what I'm needing. I'm having two issues though: 1. On render the volume is very transparent, and almost non-existent. Is there a way to beef this up? 2. The speed is about three times two fast, is there a quick way to slow it down? Thanks! Quote Link to comment Share on other sites More sharing options...
kleer001 Posted May 17, 2016 Share Posted May 17, 2016 On 5/17/2016 at 2:49 PM, tweekskratch said: Thanks so much! That's a great start for what I'm needing. I'm having two issues though: 1. On render the volume is very transparent, and almost non-existent. Is there a way to beef this up? 2. The speed is about three times two fast, is there a quick way to slow it down? Thanks! Expand 1. Increase the density in your shader. You are using the default smoke shader, right? Or increase the density of your emission. Or increase the size of your emitter. Or use a remap for your dissipation and just have it blend off at the end. 2. Easiest way, if you can, is to scale up everything else. But it also depends on what is making it fast. Turn down the turbulence? You'll have to play around wit it. 3. Check out some pyro tutorials for more info. There's lots out there. Quote Link to comment Share on other sites More sharing options...
