Arnold HtoA 1.11.2.for Houdini 15.5 Indie
  • 3 weeks later...
Hi Ray,
HtoA 1.12.0 Installed ok for houdini 15.5 indie.
I Have the arnold shaders (shop) and arnold shelf lights, but errors  when test render.
failed to render.
Error messages
Could not complete the rendering job: Error: [Htoa] Error while writing ASS file (-1).
Traceback (most recent call last):
  File "driver_arnold", line 3, in <module>
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.480/houdini/python2.7libs\drivertoolutils.py", line 8, in genericTool
    exact_node_type = exact_node_type)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.480/houdini/python2.7libs\toolutils.py", line 1182, in new_func
    return function(*args, **kwargs)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.480/houdini/python2.7libs\toolutils.py", line 1298, in genericTool
    exact_node_type)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.480/houdini/python2.7libs\toolutils.py", line 1163, in createNodeInContainer
    exact_type_name = exact_node_type)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.480/houdini/python2.7libs\houpythonportion.py", line 541, in decorator
    return func(*args, **kwargs)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.480/houdini/python2.7libs\hou.py", line 5611, in createNode
    return _hou.Node_createNode(*args, **kwargs)
OperationFailed: The attempted operation failed.
Invalid node type name
Houdini Console
 arnold1 OP_Parameters::evalIntT(): Invalid parameter name ar_log_trace_enable
arnold1 OP_Parameters::evalIntT(): Invalid parameter name ar_extra_userdata
[12:05:31] mantra: Could not find VEX shader 'arnold_vopnet' (either .vfl or .vex)
That's a known issue with rendering to mplay or the IPR. An update should be available soon, but I don't have the exact ETA.
You should still be able to render frames to disk.
Thanks for reporting
Stephen
Solid Angle Support
