Fixing overlapping geometry after sweep
mikenon
It depends how flexible you want the system to be, but a first easy approach would be to.
1-Sweep a line first
2-use triangulate 2d on that shape. this way you'll get rid of the overlapping polygons.
3-extrude the shape in the Y axis to give thickness
Thanks - Is there a way to do this that maintains enough flexibility so that the whole curve could still bend in 3 dimensions? Also, for the Triangulate2D solution, what options do I use? Every combination I tried on the model attached from original post just creates a large triangle with the swept path as sub-portions of the mesh.
Edited by mikenon
On 6/10/2016 at 6:24 PM, mikenon said:
Thanks!. Im still hoping for a way to fix overlapping polygons in general. But your solution works well for this case. Thank you.
PolyExpand2D is a great leap in the right direction, this is not a trivial issue to fix :P.
Imho you should rather develop modeling workflows that dont lead to overlaps than expecting software to magically fix bad topology. ;)
