Rendering channels in non pic format
Hi all.
I want to render my Pz and velocity variables in tga and tiff files, to use them into Digital Fusion.
Using Deep Rasters when you render to pic format is easy, but when i want to render the Pz variable to a tga or tiff file it isn't rendered.
Any clues?
Thanks
asfaik you can only render to pic with deep rasters. i think tiff and tga are only 4 channel formats (RGBA).. so you're best bet is to render your rgba to it and then render another sequence of Pz or whatever variable in seperate tiffs/tgas..
Thanks, i'm getting the next error exporting a float variable:
Invalid variable type ... specified.
In the three dots a i get the incomplete path to my project directory.
In the Deep Rasters i have put the name of my variable and Float Type, the name of the file, a tga image, and Floating Point for the channels precission, i check the filter and blending option.
I'm making any error?
Thanks
Hi all.
Any clues?
Thanks
16796[/snapback]
You can also render the passes as seperate stills/sequences, you can specify that in the Mantra ROP.
