Gas OpenCL
TheDude
I was wondering where I could learn how to make functions in the Gas OpenCL dop node? I could barely find any documentation on it aside from AMDs site, but that's a lot more low level programming related. Just looking for simple houdini-centric openCL demonstrations / examples.
Update: A friend Artem showed me where the kernels live $HFS/houdini/ocl/ -- You can open them up and have a lil dig around, but even the simplest functions take a lot of overhead to set up
Edited by TheDude
  • Like 2
  • 4 weeks later...
Has anyone ever gotten the open cl dop to work on fields?
I've been trying to get a simple scenario to work where it essentially does:
density *= 2.;
The actual code I'm using is:
kernel void test(
    global float* density_
  density_[0] = density_ * 2.0;
It throws an error saying no output field specified, I'm not sure if this is an issue with my code, or if this needs to be specified elsewhere on the dop itself?
Thanks!
  • 1 year later...
yes, it works well on volumes. Have a look inside $HFS/houdini/ocl/
The most basic example is : $HFS/houdini/ocl/sim/dissipate.cl
I'll post a file tomorrow, it doesn't seem to work well on my macbook pro at home
<_<
Edited by bunker
it might be that underscore after density.
Perhaps something like this...?
kernel void test(
		int stride_x,
		int stride_y,
		int stride_z,
		int stride_offset,
    	global float * density
int idx = stride_offset +
	    get_global_id(0) * stride_x +
	    get_global_id(1) * stride_y +
	    get_global_id(2) * stride_z;
    float density_ = density[idx];
  density[idx] = density_ * 2.0;
