Particle Bird
art3mis
Not sure which particle tutorials will point you in the exact direction for this effect, but if I were to do it I would look at advecting particles through the velocity field of a smoke sim.
I've attached a quick, basic setup which should get you going. Lots of improvements can be made to the behaviour of the smoke itself as well as adding further complexity inside the popsim.
Step 1: Take some animated geo and create a smoke sim from it (I used the billowy smoke shelf tool).
step 2: Create a pop sim from points scattered on the animation.
Step 3: Reference the velocity of the smoke sim inside the popsim to drive the particle motion.
I've used this basic technique countless times. It's a great little trick to have in your tool box.
Cheers,
WD
Ps - Feel free to use my award winning animation ;D
velocityAdvectParticles.hip
Thanks WoodenDuck, this is a fun one to play around with. I went ahead and kit boxed some detailed wings I found on Blendswap onto that bird. It does help out the sim a bit to have detailed geometry.
And you could use a twist (bend) to get some wing twisting, I bet that would create some nice turbulence as well. :)
I just love setting up that kind of auto rigging in Houdini, like having an animated wing drive a deformer, it's so easy to set up, And here's some great reference to...
Edited by Farmfield
