faxingberlin Posted July 1, 2016 Share Posted July 1, 2016 I successfully compiled VEX_example.C (code is at below the link) http://www.sidefx.com/docs/hdk15.5/_v_e_x___example_8_c.html I understand this produces Build-In VEX function like lerp(), geoself(), addpoint().... How could I use produced function in VEX? I refer to see http://www.sidefx.com/docs/hdk15.5/_v_e_x___example_8vfl_source.html. Make VEX operator and try to use function, but I can't.. Is there any example? Quote Link to comment Share on other sites More sharing options...
holycause Posted July 1, 2016 Share Posted July 1, 2016 did you create and setup your VEXdso file as well? http://archive.sidefx.com/docs/hdk15.5/_h_d_k__vex_op.html#HDK_VexOp_Installing 1 Quote Link to comment Share on other sites More sharing options...
faxingberlin Posted July 5, 2016 Author Share Posted July 5, 2016 On 2016. 7. 1. at 6:10 PM, holycause said: did you create and setup your VEXdso file as well? http://archive.sidefx.com/docs/hdk15.5/_h_d_k__vex_op.html#HDK_VexOp_Installing Thank YOU! it works Quote Link to comment Share on other sites More sharing options...
faxingberlin Posted July 20, 2016 Author Share Posted July 20, 2016 (edited) On 2016. 7. 1. at 6:10 PM, holycause said: did you create and setup your VEXdso file as well? http://archive.sidefx.com/docs/hdk15.5/_h_d_k__vex_op.html#HDK_VexOp_Installing VEX_example.C cannot print Vectors. So, I modified function. it works! it's fun. Thank you for answering again. Could I ask one more question? This is VEXdso file in $HFS/houdini/vex. #ifndef __HFS_VEXdso__ #define __HFS_VEXdso__ // // VEXdso // // This file contains the definitions for VEX plug-in functions. // // There is currently one dynamic loaded VEX instructions. // // Please see $HH/vex/dso/VEX_VexOp.html for more details. // // // Since Windows dynamic objects have a different file extension than // most unix platforms, we define a macro which makes the correct // filename. We also simplify the path construction a little. // #if defined(WIN32) #define DSO_FILE(filename) filename.dll #elif defined(MBSD) #define DSO_FILE(filename) filename.dylib #else #define DSO_FILE(filename) filename.so #endif // Define VEX plug-ins here DSO_FILE(vex/VEX_OpRender) DSO_FILE(FLU_Filament) DSO_FILE(vex/myprint) // This Line is I added. // Make sure to undefine the macro before doing any further includes #undef DSO_FILE // // When copying this file to other locations in the HOUDINI_PATH, // please uncomment the following line (or change it) so that any // other VEXdso files get processed. Also, you'll have to change the // #ifndef/#define at the top of this file. // // #include "$HFS/houdini/vex/VEXdso" #endif I add the line : DSO_FILE(vex/myprint) myfunc.dll is in $HFS/houdini/dso/vex. But, In my Setting : When I compile VEX_example.C using Visual Studio 2015, The myfunc.dll file is generated in $HOME/houdini15.5/dso So I have to move again again whenever I recompile. How Could I modify VEXdso when houdini starts up scanning $HOME/houdini15.5/dso. I try to modify like DSO_FILE($HOME/houdini15.5/dso/myprint) or DSO_FILE(/c/Documents/.../.../houdini15.5/dso/myprint), it doesn't work. This is vector print out example. Edited July 20, 2016 by faxingberlin Quote Link to comment Share on other sites More sharing options...
holycause Posted July 20, 2016 Share Posted July 20, 2016 why don't you change your output file in VS? 1 Quote Link to comment Share on other sites More sharing options...
faxingberlin Posted July 21, 2016 Author Share Posted July 21, 2016 (edited) 8 hours ago, holycause said: why don't you change your output file in VS? Thank for answering kindly. Yes, I change output directory like this. In Visual Studio 2015, Property Pages - Linker - General - Output File : C:\Program Files\Side Effects Software\Houdini 15.5.480\houdini\vex\myprint.dll But, Windows 10 needs Administor authorization to access or modify in C drive especially, Program Files. So, I solve this program by window mount using mklink. Edited July 21, 2016 by faxingberlin Quote Link to comment Share on other sites More sharing options...
holycause Posted July 21, 2016 Share Posted July 21, 2016 I wouldn't save it in the install folder but in your user directory. ..\Documents\houdini15.5\dso\vex 1 Quote Link to comment Share on other sites More sharing options...
faxingberlin Posted July 22, 2016 Author Share Posted July 22, 2016 (edited) 5 hours ago, holycause said: I wouldn't save it in the install folder but in your user directory. ..\Documents\houdini15.5\dso\vex Okay That works perfectly. Thank you! Edited July 22, 2016 by faxingberlin Quote Link to comment Share on other sites More sharing options...
ttvd Posted November 5, 2016 Share Posted November 5, 2016 Did anyone find a good way to install vex plugins without actually modifying the Program Files Houdini installation? I always modify the VEXdso file in Houdini folder in Program Files (by adding a path to the vex dso to be loaded), but is there a better way? If I create a new VEXdso file in my documents/Houdini15.5/vex/ it never gets processed. But custom dsos (not vex) installed in my documents/Houdini15.5/dso seem to load just fine. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
MrScienceOfficer Posted November 6, 2016 Share Posted November 6, 2016 4 hours ago, ttvd said: If I create a new VEXdso file in my documents/Houdini15.5/vex/ it never gets processed. But custom dsos (not vex) installed in my documents/Houdini15.5/dso seem to load just fine. That should work.... Are you by chance trying to use a relative path to the dso? I did that, and it doesn't work, I don't think it's actually called from there, though I could be full of shit . The only other thing I can think of is that you didn't change the include guard and it's being ignored? I don't think anything needs to be added to HOUDINI_PATH for it to be found. 1 Quote Link to comment Share on other sites More sharing options...
iaiotom Posted December 15, 2016 Share Posted December 15, 2016 I have this setup that works for me: in my houdini.env inside Documents/houdini15.5/ I added this path: HOUDINI_PATH=C:/projects/MyProjects/deployHOU/;& While in the deployHOU I have this structure: -vex (folder) --> VEXdso -dso (folder)---> vex (folder)---> VEX_MyFunctions.dll and this is the VEXdso file in my deployHOU/vex folder #ifndef __HFS_VEXdso__ #define __HFS_VEXdso__ #if defined(WIN32) #define DSO_FILE(filename) filename.dll #elif defined(MBSD) #define DSO_FILE(filename) filename.dylib #else #define DSO_FILE(filename) filename.so #endif DSO_FILE(vex/VEX_MyFunctions) #undef DSO_FILE #include "$HFS/houdini/vex/VEXdso" #endif 2 Quote Link to comment Share on other sites More sharing options...
faxingberlin Posted December 22, 2016 Author Share Posted December 22, 2016 On 2016. 11. 6. at 0:40 PM, MrScienceOfficer said: That should work.... Are you by chance trying to use a relative path to the dso? I did that, and it doesn't work, I don't think it's actually called from there, though I could be full of shit . The only other thing I can think of is that you didn't change the include guard and it's being ignored? I don't think anything needs to be added to HOUDINI_PATH for it to be found. Thank you ! On 2016. 12. 15. at 8:36 PM, iaiotom said: I have this setup that works for me: in my houdini.env inside Documents/houdini15.5/ I added this path: HOUDINI_PATH=C:/projects/MyProjects/deployHOU/;& While in the deployHOU I have this structure: -vex (folder) --> VEXdso -dso (folder)---> vex (folder)---> VEX_MyFunctions.dll and this is the VEXdso file in my deployHOU/vex folder #ifndef __HFS_VEXdso__ #define __HFS_VEXdso__ #if defined(WIN32) #define DSO_FILE(filename) filename.dll #elif defined(MBSD) #define DSO_FILE(filename) filename.dylib #else #define DSO_FILE(filename) filename.so #endif DSO_FILE(vex/VEX_MyFunctions) #undef DSO_FILE #include "$HFS/houdini/vex/VEXdso" #endif Thanks you! Nowadays, I study in compatible environment and I successfully implement Dijsktra Function on my own VEX function! Quote Link to comment Share on other sites More sharing options...
