Workflow for COP Velocity Blur node (velblur)?
Hi all,
I'm trying to figure out how to do post process motion blur in COPs by using the velblur node.
So far, via web & forum searching, all I've been able to find is that you are supposed to use the getBlurP to obtain a velocity plane in your output image (see attached image).
I've also attached images of both the results of rendered motion blur and the post process motion blur, so you can see that they are clearly very different (Note: the geometry is static, so this is only a motion blur caused by camera movement, if that makes any difference).
So, how are you supposed to get the velblur node to work?
I'm just guessing, but maybe the getBlur isn't working because the points aren't actually moving so there is no vel and the shader doesn't account for camera v. Have you tried animating the geo and having a static camera?
I tried with a tube moving straight down, and the result was much the same :(
I think there must be something more to getting out an accurate vel pass, I just don't know what it is and the documentaion doesn't say anything.
(Note: I think the colour space for the vel pass has changed it's look.)
Edited by Anti-Distinctlyminty
  On 7/13/2016 at 12:22 AM, 3iart said:
Here's a thread where it looks like someone figured it out
motionVectors_AOV
Expand
In the thread it says " in your shader (pyro or whatever) get 2 getblur nodes. Hook up 2 constants in their inputs - one set to zero the other set to 1. "
I tried the workflow that is outlined here and it doesn't work. Subtracting two getblur nodes alawys results in a blank image, so the time input makes no difference. I'll log it as a bug because I think it must be broken...or, at best, the documentation on this is totally unclear.
Submitted Houdini Bug #76551
Hi!
The blurred positions are not calculated if motion blur is not enabled, so the Allow Motion Blur toggle needs to be on. But if you do not wish to actually render motion blur in mantra, you can toggle off Allow Image Motion Blur, in the bottom of the sampling tab. (A bit convoluted, yes)
At least seems to work.
ee_motionvec.hip
Hi eetu!
I tried what you suggested, but it doesn't seem to work on my scene. I tried to modify your hip file (attached) to do a similar thing -have the camera move through the objects. If you go to the COP network and take a look at the output, it's just not blurring correctly.
I'm eyeballing it, but it looks as though the per pixel velocity blur isn't working. The velocity looks to be the same everywhere. Can you confirm, or is my lack of sleep finally catching up with me?
ee_motionvec_L.hipnc
Ahh ok I missed the whole velblur bit. The getBlurP thing gets you the 3d motion vector, in camera space. (P in shaders is always in camera space by default.) In your scene the vector is mostly in negative Z, which sounds plausible for things flying into the camera.
The velblur COP on the other hand expects 2d velocity vectors in screen x-y space. I tried just running the vel vector through a Transform VOP with "from space:camera to space:NDC", but it didn't look correct.
Check e.g. these
https://www.sidefx.com/forum/topic/25329/
Ok, that seems to work significantly better! Thank you! I must inform SESI that it's just the docs that need sorting out. I'm still unsure why the time inputs into the getBlur nodes need to be 0 and 1. The docs say
  Quote
Used to set the position time when the input is not connected, rather than using the Time global by default.
Expand
...so I'm not sure what inputting values actually does. As that implies that you have to connect something, otherwise it just uses the global time value.
