Ramteen Posted July 24, 2016 Share Posted July 24, 2016 Hello folks Any ideas how something like this could be achieved preferably with point vops? Thanks a ton Quote Link to comment Share on other sites More sharing options...
jordibares Posted September 21, 2016 Share Posted September 21, 2016 Careful with these mistaken effects, skin is a *lot* stiffer and heavier than people think, there is barely any sliding whatsoever. What really happens is that the muscles underneath stretch and compress and move around, then the skin does adapt to those bulges and crevices without barely any sliding. If you want to test it by yourself try going to a butcher and let you feel the skin of a lamb, camel, cow or or other animal that has been killed recently, quite a realisation i had to that respect. Hope it helps. 2 Quote Link to comment Share on other sites More sharing options...
Iskander Posted December 4, 2016 Share Posted December 4, 2016 On 9/21/2016 at 6:17 PM, jordibares said: Careful with these mistaken effects, skin is a *lot* stiffer and heavier than people think, there is barely any sliding whatsoever. What really happens is that the muscles underneath stretch and compress and move around, then the skin does adapt to those bulges and crevices without barely any sliding. If you want to test it by yourself try going to a butcher and let you feel the skin of a lamb, camel, cow or or other animal that has been killed recently, quite a realisation i had to that respect. Hope it helps. If you want to test try to find old grandma with thin skin.The rule about TS are talking about works perfectly. Quote Link to comment Share on other sites More sharing options...
jordibares Posted December 9, 2016 Share Posted December 9, 2016 Awsome Iskander... it is true that age has a huge impact on skin flexibility, tangential strength and how difficult is for the skin to recover its form. I guess I will see that for myself in in the future... ;-) Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted December 9, 2016 Share Posted December 9, 2016 It would be interesting to know how it can be done, though. Quote Link to comment Share on other sites More sharing options...
amm Posted December 9, 2016 Share Posted December 9, 2016 (edited) Usually there's underlying, nicely rounded 'profile' surface, while for that all-smoothed example, a plain copy should be enough. Then there's sort of spatial query, XYZ Distance or Intersect, to store the static offset against profile surface. Deformation is stored delta against new location on profile surface. Depending on implementation, the same should be calculated for driver object, null or whatever. Method is simple and well known for ages, there are many implementations around. While in Maya, I think these spatial queries won't fit into OpenCL - VP2 optimization, so, speed is probably comparable to Houdini VOPs or Sodtimage ICE - with a lot of queries, thing is not so fast on high resolutions. However it's possible to make it lighter, by performing everything on grid of locators, where locators are driving the skin deformer. Here is https://www.sidefx.com/forum/topic/34710/ Houdini equivalent of what I've called 'Deform by UV' for Softimage ICE, which utilizes UV texture for interpolation. It was popular while ago, anyway people used it mainly for modeling, as far as I know. Simplest variance could be a plain Maya Shrink Wrap / H Ray SOP driven by some sort of cluster deformer, but not so handy for deformations around higher angles. Edited December 10, 2016 by amm 2 Quote Link to comment Share on other sites More sharing options...
