Xeon Max Turbo Frequency and Houdini
logix1390
Besides the turbo and base frequencies, there are several speed steps in between. When running multithreaded you'll sometimes get a higher clock than the base, either for short bursts or if some cores are idle. However you can generally assume that a heavy threaded task using 100% CPU will run at the base frequency. A well-threaded task will benefit more from the extra cores than the slight clock boost from a lower-core part, though.
