Change $HOME to Another Default Folder (on Windows)
Hello guys,
It might be simple but I've been searching for this all around the web and couldn't find a proper solution.
When i'm creating a new project, it's default directory is "$HOME/HoudiniProjects".
$HOME is set, by default, to "C:/Users/Admin/Documents/"
Can I change the $HOME variable to something like "F:/HoudiniProjects"? and keep this path as default?
Thank you very much and I'm sorry if there is another topic related to this. I just couldn't find a helpful one.
Cheers,
Alvaro
Great. Thx, Michael.
I'm note using Houdini for real production projects, I'm just studying it. The problem is that my C: is an SSD with only 100GB and I can't store RnD simulations on it. With that problem I have to go all the way through another path on every single project I'm working on. That's reaaally boring.
I thought it would be a common issue but it looks like there isn't many people with this problem.
I think I'll create another - and more specific - topic on it.
studios build an environment to create and store project info...they don't rely on individual users to do things right ;)
often times a project requires a very specific combination of application versions, third party libraries (python, boost etc etc), proprietary code, project management (Shotgun etc) asset management software etc to function correctly...it's a huge issue to manage properly. The New Project feature is just a little tiny version of this for basic Houdini use.
