jon3de Posted August 9, 2016 Share Posted August 9, 2016 hi, I wanted to import a texture from COP context into my shader as a texture. So I just navigated to the path into the COP context but I always get an error that mantra is not able to load the texture. " mantra: Unable to load texture '/obj/cop2net1/OUT_stripes' " The image in the COP network is no bitmap file or anything else. Its just a ramp texture of the COP network but actually thats it what I want. I want to do that without external files. I attached a very basic scene whith to explain the problem. It would be nice to have some help here. Thank you. Jon textureFromCOP.hiplc Quote Link to comment Share on other sites More sharing options...
Guest tar Posted August 10, 2016 Share Posted August 10, 2016 try op:/obj/cop2net1/OUT_stripes Quote Link to comment Share on other sites More sharing options...
mestela Posted August 10, 2016 Share Posted August 10, 2016 Was in the middle of replying when Marty beat me to it. That said, it's being strangely glitchy for me. Refused to work with the surfacecolor vop you have, but if I swapped to a texture vop, it worked. Same with a colormap vop. Then switched back to your surfacecolor, worked, tweaked the cop network, now it's complaining that it can't find that texture path no matter what texture node I use. Strange. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted August 10, 2016 Share Posted August 10, 2016 hmmm - sounding bug worthy - it works fine with the UVquickshade, which uses a 'Layered Surface' node. Quote Link to comment Share on other sites More sharing options...
jon3de Posted August 10, 2016 Author Share Posted August 10, 2016 Yea I got it working one time with a quickshade too but after some time it stopped working again. No matter if I use "op:" , quickshade or different texture maps. Thank you anyway for looking into that. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted August 12, 2016 Share Posted August 12, 2016 Let us know if you post a bug report. I was creating a test file to send in, but it starting working again... Quote Link to comment Share on other sites More sharing options...
