Texture from COPs error
hi,
I wanted to import a texture from COP context into my shader as a texture. So I just navigated to the path into the COP context but I always get an error that mantra is not able to load the texture.
" mantra: Unable to load texture '/obj/cop2net1/OUT_stripes' "
The image in the COP network is no bitmap file or anything else. Its just a ramp texture of the COP network but actually thats it what I want. I want to do that without external files.
I attached a very basic scene whith to explain the problem. It would be nice to have some help here. Thank you.
Jon
textureFromCOP.hiplc
Was in the middle of replying when Marty beat me to it. :)
That said, it's being strangely glitchy for me. Refused to work with the surfacecolor vop you have, but if I swapped to a texture vop, it worked. Same with a colormap vop. Then switched back to your surfacecolor, worked, tweaked the cop network, now it's complaining that it can't find that texture path no matter what texture node I use. Strange.
