felix_eugene Posted August 12, 2016 Share Posted August 12, 2016 Hi guys, I got some problem here. I'm using houdini FX 15.5 My spec: DUAL xeon e5-2698v4. 40 core/80 threads RAM 64GB ECC The problem is when I do caching or Mantra Rendering, Houdini only using 40 threads, means half of the total threads available. I suspect that Houdini does not using any of the core in the Second Xeon CPU. This is very sad, do you guys know what causing this? any solution perhaps? Thanks in advance Quote Link to comment Share on other sites More sharing options...
3dome Posted August 12, 2016 Share Posted August 12, 2016 (edited) using windows? doesn't work with windows coz of so called processor groups. use linux Edited August 12, 2016 by 3dome Quote Link to comment Share on other sites More sharing options...
felix_eugene Posted August 14, 2016 Author Share Posted August 14, 2016 On 8/12/2016 at 5:34 AM, 3dome said: using windows? doesn't work with windows coz of so called processor groups. use linux oh okay, why windows why!!!! Will Ubuntu works fine with more than 64 threads? Quote Link to comment Share on other sites More sharing options...
Guest tar Posted August 14, 2016 Share Posted August 14, 2016 I think you can install Houdini on the boot USB of Unbuntu to test. It should work with all procs anyways but haven't tested. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted August 15, 2016 Share Posted August 15, 2016 (edited) What version of Windows are you using? EDIT: Never mind. Holy crap, why does Windows do that? If you have questions as you go about trying Linux feel free to ask here. Edited August 15, 2016 by lukeiamyourfather Quote Link to comment Share on other sites More sharing options...
felix_eugene Posted August 15, 2016 Author Share Posted August 15, 2016 6 minutes ago, lukeiamyourfather said: What version of Windows are you using? EDIT: Never mind. Holy crap, why does Windows do that? If you have questions as you go about trying Linux feel free to ask here. Hi, I'm using Win 10 64bit, I tried Win 7 64bit and win 8 64bit the all are the same. I tried to use Ubuntu 16 but it only shows 59 cores instead of 80 cores and Linux is too hard for me too use Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted August 15, 2016 Share Posted August 15, 2016 2 minutes ago, felix_eugene said: Hi, I'm using Win 10 64bit, I tried Win 7 64bit and win 8 64bit the all are the same. I tried to use Ubuntu 16 but it only shows 59 cores instead of 80 cores and Linux is too hard for me too use You're using the professional versions, right? The home versions are limited to a single processor socket. While it still might be limited to 64 logical cores that's better than 40 logical cores. Quote Link to comment Share on other sites More sharing options...
felix_eugene Posted August 15, 2016 Author Share Posted August 15, 2016 1 minute ago, lukeiamyourfather said: You're using the professional versions, right? The home versions are limited to a single processor socket. While it still might be limited to 64 logical cores that's better than 40 logical cores. Yes Professional version. The same thing happened with Renderman and Mantra. Also Renderman in Maya too Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted August 15, 2016 Share Posted August 15, 2016 Looks like the bug in Ubuntu is just a reporting bug. Have you tried actually rendering something in Ubuntu? https://bugs.launchpad.net/gnome-control-center/+bug/1545955 Quote Link to comment Share on other sites More sharing options...
felix_eugene Posted August 15, 2016 Author Share Posted August 15, 2016 Just now, lukeiamyourfather said: Looks like the bug in Ubuntu is just a reporting bug. Have you tried actually rendering something in Ubuntu? https://bugs.launchpad.net/gnome-control-center/+bug/1545955 I can't even install Houdini in Ubuntu LOL. I have never installing a program using a terminal and I'm lost completely.... So I think I will just stick windows and turn off the Hyperthreading. I got a clock speed improvement from 1.5 GHz to 2.2 Ghz, not bad but I lose the core amount if Houdini use the second processor group. Oh I also noticed that cooking in houdini is very slow? Is that because all cooking operation even in DOP or VOP are singlethreaded? Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted August 15, 2016 Share Posted August 15, 2016 Some tasks in Houdini use a single thread. Change the power settings in Windows to not throttle. Ever. If you decide to try Linux again it's pretty straightforward to install Houdini. I cover it in a video on cmiVFX (shameless self plug). https://cmivfx.com/store/480-Linux+For+VFX+And+CG+Production+Environments Quote Link to comment Share on other sites More sharing options...
felix_eugene Posted August 15, 2016 Author Share Posted August 15, 2016 1 minute ago, lukeiamyourfather said: Some tasks in Houdini use a single thread. Change the power settings in Windows to not throttle. Ever. If you decide to try Linux again it's pretty straightforward to install Houdini. I cover it in a video on cmiVFX (shameless self plug). https://cmivfx.com/store/480-Linux+For+VFX+And+CG+Production+Environments Wow! I will definitely check this tutorial out! Quote Link to comment Share on other sites More sharing options...
