Ber Posted August 12, 2016 Share Posted August 12, 2016 Hi everyone, What is the difference between the "pack" and the "repack" sop ? and why should I use a "repack" instead of a "pack" sop and vice versa? Cheers Ber Quote Link to comment Share on other sites More sharing options...
3dome Posted August 12, 2016 Share Posted August 12, 2016 (edited) i'm not a 100% sure. never used repack so far. but the pack sop offers way more options than repack so i guess that repack is just a slim version of pack. like if you unpack some geo, translate things a bit, just append a repack and your path attrib, etc wont be changed. if you want to change that or transfer attribs or use any option the pack sop provides you'd have to use that one. Or, in other words, repack repacks the geo into the same state as it came in. with pack sop, you have the option to change that state to a new one. at least thats what i think EDIT: found something in the journal " The repack SOP will force load all packed primitives. " Edited August 12, 2016 by 3dome Quote Link to comment Share on other sites More sharing options...
Ber Posted August 12, 2016 Author Share Posted August 12, 2016 (edited) Hi Dominik, ̶T̶h̶a̶n̶k̶s̶ ̶f̶o̶r̶ ̶y̶o̶u̶r̶ ̶q̶u̶i̶c̶k̶ ̶r̶e̶p̶l̶y̶!̶ ̶B̶y̶ ̶t̶h̶e̶ ̶w̶a̶y̶,̶ ̶I̶ ̶n̶o̶t̶i̶c̶e̶ ̶t̶h̶a̶t̶ ̶"̶r̶e̶p̶a̶c̶k̶"̶ ̶i̶s̶ ̶f̶a̶s̶t̶e̶r̶ ̶t̶h̶a̶n̶ ̶"̶p̶a̶c̶k̶"̶ ̶(̶b̶u̶t̶ ̶I̶ ̶n̶e̶e̶d̶ ̶m̶o̶r̶e̶ ̶t̶e̶s̶t̶ ̶t̶o̶ ̶b̶e̶ ̶s̶u̶r̶e̶)̶,̶ ̶w̶h̶i̶c̶h̶ ̶m̶a̶k̶e̶ ̶s̶e̶n̶s̶e̶ ̶w̶i̶t̶h̶ ̶y̶o̶u̶r̶ ̶a̶n̶s̶w̶e̶r̶.̶ Thanks! Ber Edited August 12, 2016 by Ber Wrong answere. Quote Link to comment Share on other sites More sharing options...
Skybar Posted August 12, 2016 Share Posted August 12, 2016 Did you read the help..? "This SOP takes the input geometry and repackages Packed Alembic and Packed Disk primitives as Packed Geometry primitives." 1 Quote Link to comment Share on other sites More sharing options...
Ber Posted August 12, 2016 Author Share Posted August 12, 2016 Hi David, I did but, I made a mistake when I tried "repack" and "pack" SOPs, I didn't recook correctly the nodes :/ That's why the nodes informations were false. Obviously they have same effects but for different kind of sources, as you indicated in your post. -"Repack" sop for Alembics and Packed Disk prims. -"Pack" for others geometries. Am I right now ? http://www.sidefx.com/docs/houdini/nodes/sop/pack http://www.sidefx.com/docs/houdini/nodes/sop/repack Cheers Ber Quote Link to comment Share on other sites More sharing options...
