Atom Posted September 3, 2016 Share Posted September 3, 2016 (edited) Hi All, I am trying to use AttribFromMap to scatter points only within the non-alpha area of an image. I want to do this within a thin box but it does not seem to work. When I switch a grid, however, it does work. How do I get AttribFromMap to work the same way with a box as it does with a grid? GRID: Thin Box: ap_attrib_from_map_issue.hiplc Edited September 5, 2016 by Atom Quote Link to comment Share on other sites More sharing options...
mine Posted September 3, 2016 Share Posted September 3, 2016 Maybe because in the box you only have 8 points to get the attribute from the map . Look at the spreadsheet in your attribfrommap node. Quote Link to comment Share on other sites More sharing options...
Juraj Posted September 5, 2016 Share Posted September 5, 2016 Hi, exactly, you did not have enough points to save a attribute to. ap_attrib_from_map_fix.hiplc Quote Link to comment Share on other sites More sharing options...
Juraj Posted September 5, 2016 Share Posted September 5, 2016 You can also check Trace SOP. Quote Link to comment Share on other sites More sharing options...
Atom Posted September 5, 2016 Author Share Posted September 5, 2016 Thanks, that looks like the solution. Quote Link to comment Share on other sites More sharing options...
