help to remove vertices with 2 connections, etc
Hi, everyone! I'm trying to convert blender's grease pencil strokes into actual polygonal geometry. So first i convert it to polylines in blender itself.
Then, in Houdini i fuse it  several times to get 'okeish' result.
But what I need before next fuse is:
-to dissolve vertices with only 2 edges connected.  (maybe 3 valency as well)
-to delete edges of length less then specified
Any ideas on how to achieve this? Thanks )
GreasePencil_cleanup01.hipnc
1 hour ago, tamagochy said:
Use neighbours function to get arrays and then delete points with arraylength<3. Its for vertices.
in an attribute wrangle (running in point mode) you can simply put:
if(neighbourcount(0,@ptnum) != 2)
  removepoint(0,@ptnum);
Edited by acey195
