lanchka Posted April 15, 2005 Share Posted April 15, 2005 Okay, here goes..... Till date I have been exploring houdini and have found some stuff that I cant get around 1)How do you create a polygon sphere made of quads instead of triangles? there must be some way but I have been using the convert sop with a nurbs sphere. 2)okay can the fractal sop take in quads(polygons) and output the same insread of tris?(again i end up using the convert sop from a mesh.) 3)what are the pros and cons of polygon and mesh with respect to each other? (i find that subd works only with polys....) (And for other subd modellers ,hope u try out MODO evaluation from luxology,Yumm, Really good stuff..........) Cheers Lanchka Quote Link to comment Share on other sites More sharing options...
sibarrick Posted April 15, 2005 Share Posted April 15, 2005 1)How do you create a polygon sphere made of quads instead of triangles?there must be some way but I have been using the convert sop with a nurbs sphere. 17555[/snapback] Try creating a mesh sphere and then using the convert sop to change it to polys. Same sort of thing as going from NURBs but that is the way to do it. 2)okay can the fractal sop take in quads(polygons) and output the same insread of tris?(again i end up using the convert sop from a mesh.) 17555[/snapback] No, but the VEX mountain will do something similiar it just doesn't divide up your mesh so you need more points to start with. 3)what are the pros and cons of polygon and mesh with respect to each other? 17555[/snapback] Big subject but basically because meshes are ordered rows and columns you can easily apply uv coordinates to them and change to and from NURBs surfaces. Those are the main benifits I think. Once you start using polys you have to look at subdividing to add smoothness at render time. With a mesh you can convert to NURBS. Meshes are also good for using as the basis for poly surfaces, a lot of the NURBs tools work with them and so do the poly tools. Best of both worlds. Quote Link to comment Share on other sites More sharing options...
Marc Posted April 15, 2005 Share Posted April 15, 2005 1)How do you create a polygon sphere made of quads instead of triangles?there must be some way but I have been using the convert sop with a nurbs sphere. 17555[/snapback] Put down a cube and subdivide? I prefer this methode 'cause it gives better poles than the other method. Well... better for me anyway. M Quote Link to comment Share on other sites More sharing options...
lanchka Posted April 16, 2005 Author Share Posted April 16, 2005 Also there doesnt seem to be any way of increasing the resolution of a vox primitive without polysplitting again and again Shouldnt sidefx do something about something so simple......... Quote Link to comment Share on other sites More sharing options...
edward Posted April 16, 2005 Share Posted April 16, 2005 In the Box SOP, change the Type to Polygon Mesh. This enables the Axis parameters which allow you to change the divisions. Quote Link to comment Share on other sites More sharing options...
sibarrick Posted April 16, 2005 Share Posted April 16, 2005 For more random types of shape try the bricker option in the divide sop. Quote Link to comment Share on other sites More sharing options...
stu Posted April 23, 2005 Share Posted April 23, 2005 ...keeping in mind that the bricker option in the divide SOP will create divisions within the interior of a three dimensional object, and not just on the surface. Quote Link to comment Share on other sites More sharing options...
sibarrick Posted April 23, 2005 Share Posted April 23, 2005 ...keeping in mind that the bricker option in the divide SOP will create divisions within the interior of a three dimensional object, and not just on the surface. 17723[/snapback] How do you mean in the interior? It only builds polys on the surface unless they've changed it recently. Quote Link to comment Share on other sites More sharing options...
stu Posted April 24, 2005 Share Posted April 24, 2005 How do you mean in the interior? It only builds polys on the surface unless they've changed it recently. 17730[/snapback] Uhhh, yeah, I don't know what I was thinking of...just ignore me. Quote Link to comment Share on other sites More sharing options...
