Comparing vectors in Vops
SteveNi
Hi.
I have two vectors and I want to check if they are equal or not, so this is what I did so far:
http://prntscr.com/cfxu8d
The vectors Im trying to compare are the normal of the grid (created by me in a create attribute SOP) and the vector wich starts from the grid and points to a sphere.
If the vectors are equal I set the color of the grid green, otherwise red.
In the vop sop I normalized the 2 vectors because I saw online that two vectors to be equal must have the same magnitude too, but even after normalizing them it still doesnt work.
Why?
Vectors_check.hipnc
Testing two floating point numbers or vectors for absolute equality is very unsafe.
What you should do is is test whether their difference is below a given (very small) epsilon value.
if ( ( float x - float y ) < 0.0001 )
or
if ( length( vec x - vec y ) < 0.0001 )
6 minutes ago, sasho78 said:
To answer your question in VOP context, it seems that "Compare" OP works only with float values, so you may have to use "vectorToFloat" OP and compare vector values separately and then use "And" OP to control "TwoWay" OP.
Subtract the two vectors from each other, Subtract VOP, calculate the length of the difference vector, Length VOP, compare the length to 0.0001, Compare VOP, feed to Two Way Switch VOP.
