ISUther Posted September 13, 2016 Share Posted September 13, 2016 Hello, I am trying to do perfect curve in Houdini., If you take a look at this tutorial: In tutorial scroll to time: 04:28 There you can see he is using curve tool on and as i understand on that path ivy will grow. I have created curve node as he did INSIDE of grid geo node But the curve that i have is not smooth. I need to create curve that is perfect. it should be similar as red line in the picture i added. My idea here is first to grow stalks (I think that is correct word) and then from those stalks are bending out those leaves that you can see on picture i added. Quote Link to comment Share on other sites More sharing options...
michael Posted September 13, 2016 Share Posted September 13, 2016 change your curve from Polygon to Nurbs. Quote Link to comment Share on other sites More sharing options...
ISUther Posted September 13, 2016 Author Share Posted September 13, 2016 Thank you. It works. Quote Link to comment Share on other sites More sharing options...
