Houdini NOT caching (no blue timeline)
art3mis
Hi
Following this tutorial from entagma on curl noise flow.
I noticed that the entire timeline is being cached, ie all 240 frames of the timeline are blue.
However, for some reason on my system, using Houdini Indie 15.5 and 32 GB of RAM, the timeline doesn't cache, ie only the first frame has is highlited in blue even after playing.
I'm running on a newly built custom PC, Windows 10. Is it possible there is a setting in Houdini I am not aware of? Or does this example require much more than the 32GB I currently have?
Edited by eco_bach
It could be possible you have AutoUpdate or the Brain turned off. These are both located in the lower right-hand corner of the screen.
If you are using the provided example file try diving into the geo and click the Reset Simulation button on the solver. Then try your playback again. The example file worked fine on my Windows 7 machine.
  • 8 months later...
I had an issue that looks different to yours, but of the same kind. When i was caching the simulation, the timeline was immediately orange, never blue, wich means that the image of the cache were outdated as soon as they were calculated. Also, i was able to scroll but the cache was disappearing if i move the cursor to frame 1, and i had to replay the sim entirely.
I've simplified my setup, checked & re-checked everything... Until i've been in the render panel, it was on and was calculating each frame. It was refreshing at each step of the sim. I stopped the render and the Houdini dop cache worked perfectly well then, no more orange timeline just blue !
